I concur...Seishuku wrote:Yea, just remove your center console, unbolt the inner boot, undo the dust seal, and use a snap-ring pliers to remove the snap ring that holds the shifter in place. Then pour the oil into the hole.
Sounds like a lot, but I find it to be a TON easier than trying to fill using the plug in the side.
