Transmission Question
PopPop
Car: 1990-91 infiniti Q45's, S13 Coupe, 3rd GEN. Max
How many different trans. are there for the 89-93 G50! I have seen them with the small radiator style external cooler attached to the front of the Trans. pan return line. I have seen them with no external cooler attached to the Trans. pan! Then today I noticed that one had an square opening in the Bell-housing with a screen cover over it just in front of the radiator style external cooler that attaches to the Trans. pan. You could see the back end of the Torque Converter. I'm not talking about the area where your converter bolts are! What are the differences in these Trans? If someone has pics please post and explain what the specifics are!
ceningolmo
Car: Silver 1991 Q45a & Green 1991 Q45a
I am curious about this as well... there seems to be a lot of "maybe" about the difference in the transmission's that were swapped under warranty.
Has Nissan/Infiniti ever said anything about the specifics of the replacement, the additional coolers, and why some cars got a pan with a drain plug and some did not?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Only two transmissions as outlined in the Infiniti Articles Forum, and only varied in ratios of the first two gears.
Many different filtering, recall, heat exchange, and TCU schemes. Even a procedure for cleaning the lines and heat exchangers of some of the early ones.
Why I recommend getting the TSB also. The FSM is not sufficient.
