transmission question 99Q45t..help
dzznuts671
Car: 1999 Q45t
i just went in to get an oil change and transmission flush and when the tech was under my car he noticed that the "speed sensor plug" i think thats what its called was broken and not staying on good. i guess it helps regulate the shifts not too sure. i have notice the car sometimes shifts a little weird. was wondering how common is this exactly what is this plug and if you have any idea about how much this would cost me. also how difficult would this be to replace. THANK YOU IN ADVANCE FOR THE HELP!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
It probably comes with a portion of its harness. Are you sure he did't mean turbine revolution sensor? That requires dropping the transmission.
You need to study the FSM
http://www.nicoclub.com/FSM/Q45/
And you need to call Infiniti of Sottsdale once you confirm the diagnosis
http://www.infinitipartsusa.com
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
If the tech is talking about an simple electrical connection then it should be pretty easy to rig up something to hold the connection together. There is a turbine revolution sensor that sometimes leaks fluid and is a b*tch to replace. Most drop the transmission but I remember someone saying that this wasn't necessary-maybe some kind soul will find and post the thread?
-Good luck
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
As Andy said, if it's simply a loose connector, pull it apart and thoroughly clean it. Apply dielectric schlock to the pins and reassemble. Then take a THIN tie wrap and use it to keep them "together". Carefully slide it between the wires on each side of the connector. If you can keep it centered you will have mo' betta' luck with it. Works, fast & easy. Don't axe me how I know this.
Or, buy brand new bits and tear into it.
dzznuts671
Car: 1999 Q45t
thank you all for your help! i will double check everything you guys mentioned.. i will let you know the outcome!! THANKS AGAIN!!
