Transmission Q?
ca18detizzle
Ok my CA motor is in my engine with the bolts on the mounts loose so I can adjust the transmission when bolting it on. I am running into alot of problems. I was wondering if someone could help me out. Seems like my 5speed KA driveshaft is too short, I took out that gold ring by the output shaft because it wasnt clearly the diff. Now it seems like it's too short. Also, seems like my motor is sitting really unusual. It's leaning towards the coldside alot, and it's all the way back into the firewall, really flush.
Now I came to the conclusion that my transmission is from a different CA18, not ca18det rwd. The mounts I used: 1 CA located on the coldside, and 1 KA mount located on the hotside ( reason being the nut from below the motor mount is totally stripped ) so I left it there. So is the KA mount affecting this misfitment? The transmission?
ca18detpowered
Car: 240sx hatchback, charcoal grey, ca18det
is your crossmember bolted up.?
cheap_sticker05
Car: 1994 Nissan 240sx VERT! 1995 240sx
Do you have a manual or auto drive shaft? The manual is too short which could be the problem. If you are using a KA mount and a CA mount that is why it is sitting weird. The KA mount is like an inch taller which causes the lean.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
cheap_sticker05 wrote:Do you have a manual or auto drive shaft? The manual is too short which could be the problem. If you are using a KA mount and a CA mount that is why it is sitting weird. The KA mount is like an inch taller which causes the lean.
I think you mean the auto driveshaft is too short. The 5spd KA driveshaft fits fine.
cheap_sticker05
yeah that is what I meant to say.
