Transmission Problems?
nissantuner91
Car: 1991 Nissan 240sx
Alright guys I was driving last night and then the trasmission started getting hard to shift gears. I was able to make it home, and this morning I got up to go to school and when I went to take off the transmission woulndn't go into any gears. So I turned the car off and the the transmission goes into to all the gears easy. Anybody have any suggestions on what it could be? I would really appreciate all the help.
justy90240sx
Car: 90 240sx se, 95 240sx, 92 300zx
well i assume its a 5 speed and what i would think is, if it goes into gear with out power to the transmission(engine not running) and wont go into gear with power to the transmission(engine off) i would think the clutch or clutch component would be your problem. reason being that normaly a manual transmission doesnt just go out, the syncros do witch normaly just means its hard to shift not imposible. so the only real way to no is to disasymble. let me know what u find> good luck
nissantuner91
Is it possible that the clutch is bad? I started the car in first and let out the clutch peadal slowly and the car die out. Does that mean the clutch is good?
Emperor_Tha
what shifter do u have, possible the collar on the bottom is worn out on the shifter. Common problem with megan racing shifte
Emperor_Tha
what shifter do u have, possible the collar on the bottom is worn out on the shifter. Common problem with megan racing shifter
nissantuner91
It has the stock shifter. Does is sound like a internal problem in the trans?
nissantuner91
Bump.
janda240sx
Car: 1995 240sx se
Check your fluid level in the master cylinder first off. Them check and make sure your master and slave cylinders are working properly. This really doesn't sound like a prob. with the trans. itself.
nissantuner91
The fluid level is full and when the clutch pedal is pressed you can see the slave cylinder pushing the clutch fork. Is it possible throwout bearing?
nissantuner91
My car is back to normal. It goes into all the gears now. Thread closed.
justy90240sx
what was your problem?
nissantuner91
I have no idea, it started acting up friday night. I started it sunday morning and it just went into the gears fine. I have no clue.
