Transmission problems
logan13
Car: 1991 Pathfinder
Hi!new to theboard.any help is greatly appreciated!hve 91 pathy runs good.driving down the road,went to accelerate and transmission quits altogether.vehicle starts fine but when shifted into any gear will not engage.have noticed slight variations in rpm's when shifting between gears.not sure if that is relavant.drove thru some water a couple of mile before this happened.have not had any problems with transmission before this.have had ecu problems in the past.Tahnks for the help!
03Chillinkoot
Car: 2003 Nissan Pathfinder Chilkoot
is this an auto transmission?
timmack
Car: 2002 Nissan Pathfinder SE
did ya check the fluid? ive also heard of a dirty transmission filter causing this, but not on a pathfinder. i was waiting for someone else to ask the dumb question..
bigmuley
My atuo transmission did the same thing, except it was in gear and slipped out.Drained transmission fluid, put more in, let her run for a little while, then drained out the fluid, changed the filter and filled her up again. Been running like great ever since.
88pathoffroad
Car: 1988 Nissan Pathfinder XE V6
Once again, auto or manual?
