Transmission Problems, stuck in neutral
1QUICK4
Car: SR20DET S13
I broke my 5th reverse shift fork. I had another KA transmission laying around so I swapped the bellhousings and put it in. The shifter is in what appears to be neutral, but I can't move it at all. No side to side play and it won't go into gear at all. With the car on or off. I looked underneath and the slave cylinder is pushing the clutch fork. When the car is on, if you let out the clutch the car dies, but nothing turns.
So I figured I'll take the back housing off of my other transmission and then I can pull that other transmission out and swap the forks into my transmission that I know is good, just has a broken fork. I took the roll pin out of that shifter base thing so I can pull the back cover off but it some how went into 2nd gear and I can't get it back into neutral to take it apart. I had one apart awhile ago and all i did was take out that roll pin, slide it off and then pull the cover straight off, it's been a while but i thought that's how i did it. But now i can't get it in neutral.
So it's either find out why the transmission in there is locked up, or how to get the other one apart so I can just change those forks.
Hijacker
Car: '92 240sx Convertible
'94 F-150
When you swapped the bellhousing onto your KA trans, you probably got the shifter forks off center of the bellhousing cover. It's pretty easy to do and not realize it.
