4cefed »
https://forums.nicoclub.com/4cefed-u1486.html
Sun Feb 15, 2009 5:55 pm
If it's making noise, I think it's too late. If you have a leaking seal somewhere, it's going to leak more as the trans heats up. If it were almost dry I suppose it could make a whining noise, but even if you fill it up and it goes away, be on the lookout for another trans.
I needed a wrench and a pipe to get my fill plug off, and a 1/2" impact to get the drain off. I forget the exact numbers, but I did a lot of research a while back and it is safe to use a modern synthetic (GL-5 I think?) in place of the factory spec (GL-4?).
