Transmission Problem!!!
kanecain
Car: 1993 Nissan 240SX Fastback, 2001 Toyota MR2 Spyder
Every once in a while, when I engage into 1st gear or reverse, the gear will POP into place. Anyone ever had a similar problem? I'm driving a 93' hatch.
karmakaze
Car: 98 240sx SE
kanecain wrote:Every once in a while, when I engage into 1st gear or reverse, the gear will POP into place. Anyone ever had a similar problem? I'm driving a 93' hatch.
pop into place or pop out of place?
kanecain
karmakaze wrote:pop into place or pop out of place?
It mostly happens when I go into reverse. As I put it into gear, it literally POPS into place. Making a poping noise. It happens rarely, but I want to fix it before it gets worse.
zer0c123
Car: 1993 Nissan 240SX Hatch
Does it happen if you slowly move the shifter into reverse?
kanecain
zer0c123 wrote:Does it happen if you slowly move the shifter into reverse?
Sometimes. More so if I slightly slam it. I just hear this "Ka-chunk" sound.
zer0c123
I guess its the same problem i'm having then. Sometimes (or rarely) i have trouble getting into first. If i just slam it into reverse i get the clunk sound. Sometimes i can't shift into 2nd gear forcing me to slam it into gear.
Heres my old thread i posted in the online mechanic forum.
zerothread?id=143367
I bought a new slave cylinder, butI haven't had the time check what s13sr20chris suggested. If you try it, post back here please.
Also start a thread in the NIssan Online Mechanics forum too. You'll probably get more help there.
