Ok so I just bought a 89 fastback with about 170k miles for 1100 bucks.
Why so cheap? Well there is a pretty significant transmission problem..I just dont know if its an easy fix or if I should just get a new transmission all together.
The problems are with 5th gear and reverse. I was told that it will sometimes go into 5th gear but will get suck and wont come out.
And you just can't physically put it into reverse at all ..it just wont go.
The seller said he talked to a mechanic before about the problem and he said it was because of some sort of bolt or screw that is protruding somewhere that is keeping it from going into gear.
I dont know if thats true or not..but he also said this was a common problem with 240s but I've never heard anything about that happening before.
So I want to know if this is something that someone with moderate experience can fix by getting under the car or something or will I have to take this in..or is it totally jacked and I should get a new transmission all together?
any help is greatly appreciated!
