Hi guys
Thanks you for your help!
The mecanic told me that they did not replace atf fluid only top it up.
I am stuck with that mecanic because the job is under 3 months warranty.
He s looking for a other transmission.
What i am worried about is that the problem is not the transmission but a short/electonic/sensor...
Because after the flood and all electronics replaced the first transmission acted the same (coincidence?) started with bad gear engaging then no 4 gear ,changed atf twice (just by draining the pan) cleaned filter(in pan)and woud be black in just a few road test.
Exacly the same with the second transmission that is why i am suspicious of the electronique!
The second trans is a 2001.
I have tryed tcm self diagnostic with repair manual from your web site.
And no code light comes on.
SAT717K PNP switch, overdrive control switch or throttle position switch
circuit is disconnected or TCM is damaged.
⇒ Go to TCM Self-diagnosis Does Not Activate (PNP, OVERDRIVE CONTROL AND THROTTLE POSITION SWITCHES CIRCUIT CHECKS), AT-255.
t1 = 2.5 seconds t2 = 2.0 seconds t3 = 1.0 second t4 = 1.0 second
LC EC
FE
SAT136K
TCM Self-diagnosis Does Not Activate (PNP, Overdrive Control and Throttle Position Switches Circuit Checks)
SYMPTOM:
O/D OFF indicator lamp does not come on in TCM self-diag- nostic procedure even the lamp circuit is good.
DESCRIPTION
NBAT0204S01
P PNP switch
The PNP switch assemble includes a transmission range TF switch. The transmission range switch detects the selector position and sends a signal to the TCM.
P Overdrive control switch
Detects the overdrive control switch position (ON or OFF) and sends a signal to the TCM.
P Throttle position switch AX Consists of a wide open throttle position switch and a closed throttle position switch.
The wide open throttle position switch sends a signal to the SU TCM when the throttle valve is open at least 1/2 of the full throttle position. The closed throttle position switch sends a signal to the TCM when the throttle valve is fully closed. BR
NBAT0204
PD
I have checked pnp and it s good!
I am unable to check overdrive control switch or throttle position switch because the manual is not showing the right connectors layout maybe i have the rongh manual?
This is the manual i find on your web site:
Infinity qx4 model rs50
EDITION: JULY 2002
REVISION: JULY 2003 PUBLICATION NO. SM3E-1J50U2
QUICK REFERENCE INDEX
All rights reserved. No part of this Service Manual may be reproduced or stored in a retrieval system, or transmitted in any form, or by any means, electronic, mechanical, photocopying, recording or otherwise, without the prior written permission of Nissan Motor Company Ltd., Tokyo, Japan.
Coud you please send me the right conectors layout and procedure
for trouble diagnostic over drive and throttle position !!
My vin number is :jn1vawr50a0151498
Let me know what you guys think?
Taking the car to a pro woud probably be the best way but i cannot aford it after the transmission cost!
Thanks again .
Eric
