I live in Florida so the cold season is very short but around late November when it was getting pretty cold on some days it had trouble going into gear again. I did some research and came to the conclusion that it was something called "morning sickness" related to how cold it gets and the seals contracting not creating the right pressure to allow it to go into gear, but 2 days ago it wouldn't go into gear at all, just reverse, neutral,and 1st.
I'm assuming it is now in limp mode for some reason but i'm not sure why. I connected a code scanner to it and got no codes. The check engine light wasn't on but i figured id give it a try. Iv done a lot of research but nothing matches my symptoms very well. i'm reading it can be anything from a revolution sensor, or a shift solenoid, or a messed up torque converter. I'm stumped here, this forum usually leads me in the right direction with my 240 so figured it be just as good for the altima.
Any help or ideas of things to check would be much appreciated, thanks
