TRANSMISSION PROBLEM SR20
Taino_96_sr20
Car: Nissan 240sx
Ok i just changed my clutch, throw out bearing,and my master cylinder also removed my dampener box .When i go to bleed the slave it builds to much pressure and the spring in the slave pops the metal thing in the slave to far and it pops out and i loose pressure i tryed adjusting the clutch pedal rod but the slave is still popping out.do i have to buy a braided steel line to make the pressure not be so strong. PLEASE HELP ME!
Modified by Taino_96_sr20 at 5:41 PM 12/20/2009
Modified by Taino_96_sr20 at 5:44 PM 12/20/2009
r3v_v3ng3
Car: 91 fastback ka-t
Taino_96_sr20 wrote:do i have to buy a braided steel line to make the pressure not be so strong.
dont think buying a braided line would make your pressure less stronger. any pics of that metal thing your talking about?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I think you just need a new slave, you did everything else. Plus its in 3 pieces now, not good.
Taino_96_sr20
Car: Nissan 240sx
I'm on my 3rd slave cylinder the slave in the pic is my old one plus u can just hit the slave on The ground and it will pop out every slave I get same thing happens
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Third new, or third used / junk yard slave? I would try a new slave, line, and CMC with a proper bleed.
Taino_96_sr20
Car: Nissan 240sx
My third slave is brand new out the box the one in the picture is my first one it's old
triple r
Car: 1991 nissan 240 sx se
ever think of the master.....it may have something to do with it
Taino_96_sr20
Car: Nissan 240sx
Yea I'm just gonnA goahead and replace the everything slave, line, and master if that doesn't work the to a mechanic she will go.
l3thalyendl3ss
Car: 91 180sx ka-de na
hey not to be a retard here but put the damn seal back on there and put a clamp around the bottom of the damn seal and call it a day easy track fix that worked on my daily its been 3 months like that I dont touch it. it just works try it if it dont work ur F&&&&&D just buy a new one.
Not used new new oem replacement new
