joe603 »
https://forums.nicoclub.com/joe603-u34652.html
Tue Feb 16, 2010 5:43 am
Ahhh the dreaded clutch chatter
Perfectly "normal"...though it is annoying huh. The reason is simple. The OEM flywheel is a dual-mass design. It was used because the transmission gears are beefy and the transmission case is thin. The weights on the flywheel help smooth out the engine pulses. When using a lightweight single mass design, this translates into gear lash noise from the pulsing.
Search the forum for tons of posts on this.
Welcome to NICO!
