Transmission Problem, I think.
Hstn Wytt
Car: 1990 Nissan 240sx
Alright so I just got my 90 ka24e running, Ive had 3 motors go bad in the past two years, I havent even put more than 2000 miles on this car myself in the two years ive had it. And about a week ago, I got a new engine to put in it, and it runs the best it ever has, no rattles, no knocks, no weird noises. Well a couple days ago it started making this weird noise, I believe coming from the transmission, now this is the same transmission that has been in it the past two years. Any time I just push the clutch in or try to put it in gear from neutral it makes this griding noise, sounds like Im missing a gear but Im not. Sometimes it does, sometimes it doesnt. Is a new clutch the solution? This hasnt happened to me before in any car and just making sure before I shell out more money.
Im scared to even drive the thing right now bc of all the problems ive had wrong with this car, the smallest weird noise, and this car is parked until i figure out why.
S13_RB25
Car: A 240 but no RB yet!
Well do you have a aftermarket clutch?? Also did you remove the damper box from underneath the car? Check your MC for low level of fluid.
Hstn Wytt
Aftermarket clutch? as in a clutch other than the one that nissan put in or a performance clutch? bc im 99% sure its not the one nissan put in and no its not a performance clutch. no to the damper box. my dad said all the fluids are fine.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
regardless the fix, you are going to be dropping the trans.
Which isn't complicated at all. like 10-11 bolts including the 2 starter.
Drop the drive shaft, grab a jack and support it, Take out shifter, drop the trans mount and wiggle it out and mind the sensors. 3 switches and a speed sensor. inspect clutch and freshen up the trans.
And drain the trans before removing, examine fluid for metals. PBblaster is your friend.
alms24sebring
'04 Nissan Sentra SER SpecV
Dont forget the exhaust..
