transmission, power str, and brake fuild ??????????
rocwyld06
Car: tuning, sports, cars, tv, etc
what is the best kind of transmission, brake, and power steering fliud to use. if i use synthetic, do i need to drain/bleed the brake lines, pwr steering lines, etc?
180fan
Car: 89 fastback
brakes yes you should flush completely out the old stuff. Doesn't matter if you're switching to synthetic or not, get out all the old stuff. Personally I use ATE super blue and switch with type 200 to check over the colors. The motul RBF soaks up water like a sponge. I'd recommend staying away from that. If you've got oodles of money to spend, get the Castrol SRF. It'll cost you alot but it's amazing.
transmission I use Redline MT90. Some guys use the Redline Shockproof, but they didn't have that at my local race shop so MT-90 it is. GL-4 only!!! You'll still need to drain this anyway.
Power steering, just use regular old dexron III ATF. I use the castrol stuff but doesn't make much difference as long as it's dexron III ATF.
