Transmission People, gather<----!!
alfsnissan
Car: 1995 Nissan 240SX
Ok, Car- 1995 Nissan 240sx 5 speed with stock motor and trans.Problem- When driving and I crack my window, a draft starts and pulls a burnt smell through the car. Its transmission fluid and when in good sunlight, I can see the smoke coming up from the shifter boot. I checked the fluid and its fine, you can smell its burning. Question- How or why would it be burning?
Thanks, Adam.
Roger_cha
Car: 91 nissan 240sx
well is you transmission leaking... if it is then its leaking on to you exhaust pipe check to see if you have any fluid on you cat or exhaust pipe...
alfsnissan
No leaks that I can see. When I removed the plug to check the fluid, the smell was strong and then I smelt the cap and its strong on that to. Somethings going on in the transmission and I dont know what it could be or why its doing it. Thanks Adam
slideways13.4
Car: 91 coupe 93 hatch
how long have u had the car? have you ever changed the fluid.
alfsnissan
I've had the car for 6 years and changed the clutch/pressure plate last year and changed the fluid then. Thanks Adam.
alfsnissan
How often are you supposed to change manual gear oil? Thanks, Adam.
