Transmission pan leaking
maxwell867
Car: 1996 q45
Finally jacked up my 96q and found out where my transmission fluid leak is coming from. Seems the pan is rusted on the bottom and the fluid is leaking through. Does anyone know how much a new pan is from the dealer and besides the gasket and filter what else should i change? Didn't see any posts, if there are any point me in the right direction. Thanks in advance.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Seach on transmission flush.
You will need the one time use bolts also.
Sure the upper turbine sensor is not leading also?
maxwell867
Car: 1996 q45
THANKS FOR THE POSTS. THE LEAK JUST SEEMS TO COMING FROM THE PAN BUT I WILL CHECK MORE THOROUGHLY THIS WEEKEND.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Personally I would get a used pan, but a new one isnt very expensive...
