cbh148 »
https://forums.nicoclub.com/cbh148-u148773.html
Fri Feb 10, 2012 10:13 am
If 1) you used the same clutch during both transmissions and 2) the slave cylinder was not the problem and 3) you never tried adjusting the clutch pedal through any of this, it's possible that your clutch isn't completely disengaging when you mash the pedal down.
I'm talking about the linkage that connects your clutch pedal to the master cylinder. It has a jam nut on it (12mm) that must be loosened, then you can twist the rod itself with your fingers. In your case, you'd "unscrew" that rod out of the pedal linkage a bit (which will move the pedal closer to the driver's seat) then tighten the jam nut back.
This will make your clutch disengage even more, and if that's your problem, then this'll fix it. Hope this helps.
