Freakazoid »
https://forums.nicoclub.com/freakazoid-u51618.html
Thu Jun 07, 2007 8:13 am
I managed to get hold of the VK45 engine side pattern and made a trace of the VH45 pattern. Most of the bolts are the same. One or two on the bottom half seem to be swapped from one side to the other. I cannot confirm this to be exact since I don't have a VK but the source is very reliable. I got the VQ35 pattern from the same source and have managed to get to a adaptor plate design.
The reason I am asking about the Frontier is that at looking from behind it looks similar to the VQ35, but which one I don't know.
Thanks for the info, it makes finding the right parts easier. Is there some source where I can find all the transmission numbers and which engines they came with?
T45: I was seriously thinking of the auto, to the point where I ordered a cut-out one from Japan. But for my needs a auto is going to cook, we do long stecthes in sand, then in mud and then on the rocks. Auto's just seem to cook if you don't spend a serious amount of money on cooling.
As for the models of Nissan, we have never had any version of a V8 Nissan in this country, pity. We actually get a very small range of cars frome each brand.
It definitely looks like the Navara box and transfer is the right way to go. 1st Gear is 4.6 and the transfer case is 2.6:1. Great for rock crawling. If the bolt pattern is similar to the VQ35 then it should be possible to make and adaptor plate.
Thanks again.
