transmission oil
Leo123
Car: Infiniti Q45, Nissan 180sx,
Should i use dextron 2 or dextron 3 ATF for my transmission. miles 125,000+
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Not trying to be rude or anything but the answer to this question and more is in the links I provided you in the first topic you made.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
didnt know you could buy Dextron II? Dextron III is the stuff you need, its the most common ATF.
Leo123
i was just want to compare the 2 brands and the differneces
qship96
Car: 1996 Infiniti Q45
Leo123 wrote:i was just want to compare the 2 brands and the differneces
dex 3 superceeded dex 2 almost 2 decades ago, and both are now superceeded by dex 6. While the older formulations can be found, they are not "officially" Dexron , as Dexron sopped licensing them when Dexron 6 hit the market.
Just use a Dexron 6 product and you will be fine.
