kuuligan wrote:
dam...i should have used redline
Well, I've no basis to compare AmsOil, so can't say it's not just as good, only that I'm very satisfied with Redline.
Quote »My transmission grinds going into 2nd too. Also grinds abit if i drop it into 4th from 5th at high speeds[/quote]Rev-match when you downshift, that'll take care of that problem.(tap the throttle a little when you push the clutch in, just before shifting)
As for not liking 2nd...if I let it idle a minute or two (depending on the outside temp), then it's no problem.
