Transmission Noise
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Hello All,
I have been noticing a weird noise when going through the gears in the higher rpms. Almost sounds like a whirrling noise is best i could describe it as. This only happens around 4-5rpm's when going through the gears. Not sure what it is but hoping its not my transmission going bad. Also the syncros had been replaced at 60,000 my car now has 109,000.
bbecker17
Car: 1991 240sx.... dead
1990 300zx tt jdm
its called gear whine some of the gear in the transmission are just becoming worn thats all
fabbio25
Car: 2014 Evo MR
1990 Z32 TT
Does that mean my transmission is on its way out?
ZeeTree
Car: 1990 300zx na
I had this problem only when cold. Replaced the fluid with redline synthetic. It fixed it. The fluid Nissan had recently put in was apparently garbage. It also had a sort of shimmy or shake, kinda felt like a bad tire, but only when cold. The new trans fluid fixed that too.
McShanks
Car: 1990 300ZX 2+2 VH45 with custom engineering in progress
Awesome, ZeeTree, I have similar issue and I will give redline a try. Where is it sold?
stewartmotorsport
Car: 1993 NA
1988 Turbo
1987 NA
2002 SL55
2002 CL63
1988 560SL
You can get redline just about anywhere. I think even Autozone and O'Reilly sell it.
