Samurai C »
https://forums.nicoclub.com/samurai-c-u96697.html
Fri Apr 23, 2010 7:14 pm
I have the same noise in my car. So I rebuilt the trans and its still there. Thought it was the input shaft bearing too. I put brass, bearing, and seals in mine. My trans guy and me took it back apart and couldn't find anything wrong so now I'm going for gears, shafts, and idlers, but Ill explain my noise a little better and you can see if it the same. I had a noise like a bad power steering pump and when I pushed the clutch in it went away. On the highway when I let off the gas the bad power steering pump noise when away but i also had a grinding noise in 3rd and 4th went I let off the gas. When I gave it gas I had the bad power steering pump noise but no grinding. So see if your noise is similar and ill let you know how i make out in about a week or two. I'm still trying to find a used unit to swap the everything over before I spend The $600 on new stuff.
