centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Jul 07, 2006 7:32 am
Hey, so I was on the NICO site searching for someone who’s had the transmission problem I have. I found a sound clip by SlowBack and can say I hear the same noises coming from the bellhousing area of my car. What was the problem and how do I fix it? I found the sound goes away if I just leave it in neutral and depress the clutch. When it’s in idle with the clutch closed, the noise is faint. When I put it in gear and drive the knocking gets horribly loud and now a squeal has added to the fun. This actually happens in all gears. The sound becomes less at a maintained speed, but any acceleration makes it real loud. Could my issue just be as simple as a bearing or fluid? Should I start saving for a replacement transmission? How long can I drive until something breaks?
