elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Apr 11, 2006 4:04 pm
You can check the codes the old fashioned way...
Warm the trans up sufficiently (temp gauge in the middle, drive for a little while), then do this....
This is all done without the enigne on.
1. Shift the car into drive2. turn the key back off, and while turning it on turn the trip reset thing counter clockwise. it should say AT CHECK, if it doesnt, turn the key off and try it the other way.3. shift the car into 34. press the gas all the way down and release5. Shift the car into 26. Shift the car into 17. press the gas all the way down and release...
Then maybe 20 seconds later it should give you a readout. Post back and we can go from there.
