bigdog76 »
https://forums.nicoclub.com/bigdog76-u33673.html
Fri May 16, 2008 6:58 am
I will do what Elwesso says Then I will post codes
"with the key initially off, hold the reset of the twin trip meters counter clockwise (try both ways, i cant remember which one does it)... you should get AT check (if it doesnt do it counterclockwise, try the other way)..... You turn the key on while holding that to one direction or the other. Also, before you do this shift the car into drive and put on the parking brake...
once you have the AT check, shift to 3, fully depress and release the gas, then to 2, then to 1, and fully depress and release the gas. Then give it a couple of minutes and it will tell you the codes on the readout
