transmission making noise when decelerating
davisber
Car: 1993 Infiniti G20 sedan 2.0
I had my transmission replaced with a used trans and at first it was erratic about changing to the second gear. I added the transmission additive by Nissan and it finally started to shift with no problem. Now I get this sound when decelerating or coming to a stop. What could be causing this ?
frapjap
'07 Subaru Legacy
Glad you got some of the problem taken care of. Have you had the chance to see what the fluid looks like? Did the shop that replace it change the fluid and filter of the used transmission?
davisber
The fluid and filter have both been changed. I read some where that the pump in the transmission may need to be replace or a solenoid may be bad ?
dorcom
Car: 98 Nissan Sentra SE
Hi
I too got that transmission whine on deceleration!
I just bought a '98 Nissan Sentra SE with 187k miles in California.
2.0 engine, A/T
Passed smog and all seems well.
Nice car, runs great but...
Except that transmission whine when decelerating.
It becomes very audible below 20mph.
Although you hear it at higher speeds as well.
Shift into "2" and the sound is less.
Although it all shifts fairly well I also have that shift issues from 1st to 2nd.
Worst when under hard acceleration or cold.
Almost like a slipping.
Shift takes several seconds with engine not dropping revs. eeek!
This morning up a steep hill would not shift into 2nd. Yaiks!
Engine just reved up.
Fluid flush had been done by PO about 15k miles ago.
ATF color is pink-red and clear, nothing brown.
Have you found out what is the cause?
Anyone know what this could be?
Rob
