transmission making noise
NISMO24096
ok well before everyone yells at me, here is my problem, i just had my clutch replaced last nite, and well needless to say the people that i had do it did not bring everything they needed to do it 100% what i mean my this is they did not have a press to press out the old throw out bearing and put the new one in, well anyways now when i have the clutch pressed in the transmission makes a whining noise, im guessing that its the throwout bearing, or could it be someting else, they told me that if it gets worse they will bring the stuff they need to redo it right, understand i had to have it done at my appartment cause it was not driveable, otherwise it would have went to a shop, anyways what do you guys think, throw out bearing or something else.....:help
NISMO24096
come on guys. heck i dont even care if ya do yell at me about this just help me figure out it is the throwout bearing or if it cauld be something else, like i said it does it when you press the clutch in, it does not matter if its in gear or not , and after you drive the car awhile and get the transmission hot it does not do it . or at least its not to the point where i can hear it and the vibration in the gear shift is minumal, where as when you first crank the car it is a very audible whine and can be felt through the shifter... thank for any replys....
Cyberkreig
Car: 1993 Nissan 240SX SR
I honestly have no idea. but i was once told to never ever replace a clutch and not the TObearing at the same time.
