AZhitman »
https://forums.nicoclub.com/azhitman-u113.html
Mon Feb 02, 2015 9:14 pm
Let's start with simple stuff, moving to harder stuff.
Shift lock solenoid is the most common cause, and has been documented elsewhere with other Nissan models. It's under the console, and you can pull up the FSM (nissanservicemanual.com) to find it. Dealer should know about this, and should have no issue getting you one if it's bad. Easy to test - Run 12v from the battery and ground to the 2 terminals respectively, it should pop. If not, it's dead.
Make sure ALL fuses are good, especially the one for the shift lock system - should be fuses 12 and 21 (junction block fuse box).
Make sure your brake lights are operational - Replace brake light switch if needed.
Find the shift lock control unit (behind the gauge cluster) - make sure power and ground to the shift lock control unit are good (multimeter needed).
Replace the shift lock control unit with a known good unit (the dealer may be able to help here).
Apparently there was a TSB for this, which calls for replacing the shift lock solenoid AND/OR the shift lock control unit.
