Hello again everyone,
My 1994 300zx light comes on in the gauge cluster when I turn the power on, however turns off when I actually start the engine. Is this normal for 300zx's or not, do I have a transmission problem? I know that when you turn the car on the check engine light is suppose to come on then turn off when the engine is started. Does the transmission light work the same way to where its checking that all systems are working properly?
