Either one as they're the same. I replaced mine a long time ago and it still leaks.xero1 wrote:is that a ka24e or ka24de seal?
Mine does this same damn thing and it's ruining clutches. i'm going to replace the disk again and i'll let you know what I find. the only thing i can think of is I didn't put gasket sealer on the trans front cover bolts like the fsm says. I did all the gaskets inside the bell housing and the rear main seal last time.f150intally wrote:mine leaks and drips out of the bell housing. I replaced the input shaft gasket when I had the transmission out last time and it did not help. Mine leaks more than 1 drip a day though.
