S13_newbie »
https://forums.nicoclub.com/s13-newbie-u7738.html
Mon Oct 24, 2011 10:03 pm
Hi. I have a 98 Infiniti i30, w/ lsd. The car has 120,000km on it, and i bought the car used, and until recently I found out the car tends to like to stays in 3rd gear even though I slow the car down to about 10mph, as long as it is not a complete stop or a big step in the gas pedal, it will not go kick down to lower gears. I thought I saw some post about the MAF sensor is not detecting enough air for the TCU to kick down. Can someone gimme some ideas on where should I start to pin point the problem?
I have flush the transmission fluid w/ Mobil1 syth ATF, and replaced oem transmission filter, and oem pan gasket when It was done. The fluid replace about 10,000 KM ago.
Thanks in advance.
