Transmission issues
whitedragon551
Car: 2015 Nissan Murano Platinum
Finally got all the parts replaced on my SUV. Only thing that's left is to get it up to speed.
I swapped throttle position sensors under warranty and took it for a test drive. I still wasn't able to get it up to speed. I parked it and put it in neutral and swapped from rear wheel to 4 wheel. I couldn't accelerate past 10mph. I parked again to swap back and upon swapping back the indicator lights near the speedometer started flashing high lo. Only way I could get it to stop was to move the switch on the dash from 2wd to lock or shut the truck off and restart it.
Here is a quick video I took. At the end is where I move the switch to lock.
https://www.dropbox.com/s/7jmm9409esj8yx9/IMG_0093.MOV
What would cause this issue?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Are the transmission fluid and transfer case fluid levels correct? How is the condition of both fluids?
You can try the TCM self-diagnosis procedure described on page AT-44 to see if that will yield any insight. I can't look at your video right now, sorry.
I really don't know too much about the workings of the 4WD systems and how to troubleshoot them, so hopefully someone else may have a better idea.
whitedragon551
Took it to the shop for a free estimate where I know the owner. Definitely a transmission issue. Everything is reporting correctly with sensors so he doesnt know what it is unless you takes it out and rips it apart.
Vehicle is going to the scrap yard.
Slumpert
Car: 1997.4 Pathfinder
Ack scrap yard? Anychance your near Houston... I might take on a new project since my daughter doesn't let me drive mine much..
whitedragon551
Truck is located in west Michigan.
