So I've done some reading up on the TPS here and a few other places. I think I'm having a problem measuring the voltage or I have a problem I don't understand. I've tried two different meters, measured with the car fully warmed up at idle and they are both reading from .10 to .18 volts DC. The voltage doesn't seem to vary much with an adjustment of the TPS position, but it does have a noticable effect on the idle and how it shifts/drives (as you might expect) which is why I'm thinking I'm just not measuring it correctly. I tried a new TPS and it gives the same voltages (.10 to .18 volts). I am using a bare copper wire and inserting it, as best I can tell, in the wiring harness as it is in this thread (
zerothread?id=409495). My harness is different, tho, probably because it is a 97 instead of a 93.
Below should be a picture of my harness, I inserted a red wire in one picture into the slot I've mostly tried, but I've tried a few other places, including the gray harness below that one, to no avail. After some trial and error adjusting the TPS, it is driving reasonably well again but it would be nice to get this all sorted out....without a trip to the dealer, but I sense that is where this is headed.
