transmission issues
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
im starting to have transmission issues again. i did a transmition flush at the nissan dealership, it didnt help much but it seems as if when it is cold outside, the transmision doesnt want to shift past 3rd gear. so when im driving about 50mph it acts like it is going 65. then a few stop lights will pass and the car warms up completely it will shift normaly. do you guys have any ideas of what could of went bad?
pathfinder_se_black
any help is appreciated. am i the only one that is experiencing these problems?
KoukiS14
Car: 2005 Infiniti G35x
Lakeshore Slate / Stone
I dunno. . I can say that when it's cold, mine def. doesn't shift quickly at all. I guess I haven't driven at that speed when it's cold, as I can't possibly get to a road with that sort of limit before it's warmed up.
plugnickle
Car: 1999.5 Nissan Pathfinder LE
I was preparing my 99.5LE to tow (BAD IDEA) and I replaced the stock fluid and filter with B & M Trick Shift. It really helped the way my ride shifts. My ride had a bad habit of staying in passing gear while in cruise after topping a hill. The fluid change helped this also but it still tends to stay in passing gear too long.
Don't Tow with no 3.0!!
KoukiS14
Yeah I couldn't imagine what a 3.3 would tow like. . says you can do 5k lbs, but I'll bet it's crazy slow.
plugnickle
3.3???? I wish , try a 3.0 I believe this is the most under powered vec. I have ever owned but I love it!
KoukiS14
plugnickle wrote:3.3???? I wish , try a 3.0 I believe this is the most under powered vec. I have ever owned but I love it!
Sorry, I was going by the user text that says you have a 99.5 (96 - 00 had 3.3).From my perspective, it's not that bad -- I don't tow anything, but I compare to my last SUV which was a 91 Isuzu Rodeo with the GM 2.8. The engine put out 120 HP
I worked at SIA in summer of 2000 (which WAS Subaru / Isuzu) locally, where they made all the Rodeos, and I drove literally hundreds of all worldwide versions of that thing ... the 4 cylinder was a VAST improvement over the old 6.
