Transmission Issue
pathfinder_se_black
Car: 2000 pathfinder, FG2 civic si
Alright, when i drive my pathfinder after being warmed up, the transmission makes a buzz noise at the beginning of first and the end of the second gear. but it goes away after about 10 min along with the overdrive not wanting to kick in. the overdrive kicks in about 4 miles later. does anyone have a clue what this could be or does anyone have similar problems? i already had a flush done at Nissan. fluid level is ok.
SnowSurfLax
Car: 1999.5 Infiniti QX4
2006 Infiniti M35 Sport
OD doesn't lock up until your transmission comes to operating temp (NO JOKES KOUKI!)
As for the buzz, probably just making a heat shield rattle is my first guess.
pathfinder_se_black
the buzz only occurs when the truck is in gear. it's so odd.
SnowSurfLax
yeah, fits with a heat shield. Only makes the resonation at a specific vibration. Usually requires the car to be under load to get the specific vibration.
Or it can be the transmission about to blow. I'd have a trust worthy mechanic drive it and give you an opinion.
bmlawless
Car: 1999 Infinity QX4
SnowSurfLax wrote:Or it can be the transmission about to blow.
Can we make a joke now.
