daoracle_sentme »
https://forums.nicoclub.com/daoracle-sentme-u66177.html
Fri May 25, 2007 3:03 pm
Thanks for all of the info on the last post guys. My dilema is I dont have the money to totally fix the transmission. My plan is to see f I can salvage what's left or if not I will just cut my losses and sell it. So the question is what step should I take
#1 Drain sum of the fluid and replace 3-4 quarts or#2 Just drop the pan change the filter and all and just refill the fluid.
What are the potential downfalls for doing either action?What is the best fluid to put in afterwards?
I have been told that I run the risk of making the problem worse if I drop the pan? How true is that? Does the same hold true for a simple drain? Is Lucas good or bad? If it's bad whats a good additive to add if I should add anything other than ATF?
I know my questions may sum dumb to most but I truly appreciate the help and truthful guidance that I have been given thus far on this issue. Thank You.
