Transmission identification?
1962-1965 Datsun L320 and NL320 forums - The truck that started it all in the US. All 320-specific topics and discussion can be found here.
fogdart
Car: 65 Datsun 320
Hi, New here... I'm building up a 65 320 from a couple of parts trucks (both 65s, one E1 4 spd column shift, the other a J15 4 spd floor shift).
Transmission has me stumped. 4 speed floor shift that was bolted to a J15 in one of the trucks. Didn't work because the clutch disk was a 24 tooth and a bit too large for the transmission's 20 tooth shaft...just spun inside the hole. Clutch disk is 200mm. #'s on transmission are No 4 5-29 and 6-4-1 ???? Looked to be a stock transmission installation as mounts are not modified. Just don't know what to ask for when I go looking for a clutch disc. I'll try to post a photo of the transmission but am having trouble making that happen. Thanks for any help on this!
BTW, I have the complete column shift transmission setup including all shift linkage, mount plate, clutch and transmission that I won't be using if anyone's interested....let me know. I drove this 300 miles just before I disassembled the truck so I know it all functions well. I'm committed to the floor shift now...otherwise, I might use it myself. [IMG][/IMG] [IMG][/IMG]
fogdart
Car: 65 Datsun 320
....turns out that the transmission was originally bolted to a J13. Found a 'dimensionally correct' disc on ebay today. Looks as though it will work fine...we'll see. It matches the part # in the 320 manual and is correct diameter and tooth count....7 7/8" (200mm) with 20 teeth. NAPA and CarQuest did not have clutch info that far back. Will post with part numbers once I receive the disc.
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
Cool info! Thanks for posting it up.
tonylopez
Car: 1965 datsun model 320 1200
looking for a 4 speed transmission on the tree and a front windshield. Email me at [email protected] thank you Tony
tonylopez
Hello fogdart. It is very difilcult to comunicate throught this forum, I am having a hard time following who's who I am comunicating with , My email address is [email protected] it is much easier for me to with email method. now do u have a 4speed transmission not on the floor ,but on the steering colunm(4 speed on the tree) 1964 datsun 320 pick up truck.Please let me know Tony
Return to “Datsun 320”
