Transmission help..
huey29
Car: 1990 240sx
Quick question.. I know it's on here but is there any other transmission's you can use with an s13 sr?
edwards30
Car: 1995 240sx SE
i think a KA transmission will work but have to switch bell housings. Not 100% though
moffitt
Car: 92 S13 Hatch with Redtop SR20DET W/KA Transmission.
Yes the KA transmission will bolt right up to the SR Bellhousing. But when you swap the bellhousing, BE SURE TO PUSH THE SHIFT FORK THAT POPS OUT OF PLACE, BACK INTO PLACE, or you will not be able to shift into 3rd,4th, 5th, or reverse gears.
