BuudWeizErr »
https://forums.nicoclub.com/buudweizerr-u1639.html
Sat Mar 29, 2003 2:10 pm
It's not too difficult.
2 bolts hold the driveshaft in place, drop that, the driveshaft will drop down. Make sure you have a bucket, all your transmission fluid will come pouring out. Then there are four bolts holding the transmission crossmember on, drop those, and hold your transmission up with a jackstand. Unbolt the two bolts holding the slave cylinder on, and unhook the wiring harnesses. Then there should be 15 bolts holding the transmission to the engine (IIRC) (will need to be retorque'd). Don't forget to unbolt the starter seperately, otherwise you might drop it.
After that, a bellhousing swap is in order. I haven't done that, I don't know of any problems that may or may not need to be remedied, but it shouldn't be a real difficult assignment. A new TO bearing and pilot bushing probably wouldn't be a bad idea.
