reefscape15 »
https://forums.nicoclub.com/reefscape15-u262757.html
Thu Jan 26, 2017 4:55 pm
Hey guys, another question. I've had this car for only a short time, about 8 months, put 10k miles on it so far. Had 146k when I got it. I noticed very quickly that when it shifts into 3rd gear under heavy throttle, it really slams into gear, so violently that it shakes the whole car. I've avoided this as much as possible. When the engine is cold, it still happens even under half throttle. Also I have noticed it if I'm really pushing the car and using the "sport shift" mode going from 4th down into high RMP 3rd gear. transmission fluid is perfectly clean and full on the dipstick. Not sure if it's ever been changed or not. Is this a common problem? Anyone? I'll have time to drop the pan and change filter/relpace with fresh fluid. Any info on any of this? Thanks again in advance
