Svtrit »
https://forums.nicoclub.com/svtrit-u284280.html
Fri Dec 02, 2022 2:06 pm
When it gets cold, as in 20 degrees or less, my transmission seems to hang up and require high RPM to keep the car moving. After I get to about 1/3 warm on the temp gauge, the transmission settles in and operates normally. High RPM means 3000 rpm at 30-35 mph.
I am due for an oil change, and usually do it myself, but was thinking of taking it in to have a transmission update done along with the oil change, if this is a software issue. Anyone else have this issue?
The car just turned 19,000 miles and is a 2019 SLAWD.
Thanks.
