Pipe wrench on the lug not the socket, the fill plug is a square lug, once you bite onto it with a pipe wrench and add a 4 foot cheater pipe it's coming out, might break the case but it's coming out.camarokid wrote:if your breaking sockets the pipe wrench is only going to break them faster.
I'm no expert on these transmission but wouldn't the heat burn up/melt the synchros?G-E wrote:You'll need to torch it, don't worry about boiling the fluid, you'll drain it anyway... just try to localize the heat as much as you can to the plug.
a square lug that sticks out?evildky wrote: Pipe wrench on the lug not the socket, the fill plug is a square lug, once you bite onto it with a pipe wrench and add a 4 foot cheater pipe it's coming out, might break the case but it's coming out.
