peterkehoe »
https://forums.nicoclub.com/peterkehoe-u270587.html
Wed Dec 28, 2016 8:31 pm
It could be many things.
If your car is automatic, its likely the cooler was damaged in a front on hit. In many cars this is integrated into the radiator. Have a look under the hood and under the car see if you can see it. Obviously you should check the level of remaining fluid before you drive it.
