Transmission for a 1998 QX4
magius311
Car: 1998 Infiniti QX4
My fiance and I just purchased a used 1998 QX4 for a good price, knowing the transmission needs replacing, but I'm having some issues finding one. I know that a '97-'99 transmission from a QX4 would work fine, but to open options up, I'm wondering if a similar year Pathfinder transmission would work. The RE4R041A Transmissions were used in many different vehicles. Would those work?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Yes, any 96-00 Pathfinder / QX4 transmission will work.
magius311
If I were to put a Pathfinder transmission into it, would I need to change anything, such as the electronics?
Towncivilian
It should bolt right up and be electrically compatible. People swap in 01-03 Xterras into their 87-95 Pathfinders and don't change the TCM so I believe there shouldn't be a problem in your case.
magius311
Alright, then. No changes from the different computer or anything else? The availability of the pathfinder transmissions is much higher.
Towncivilian
Nothing that would significantly affect transmission operation.
magius311
Thank you, so much! That opens so many more opportunities.
