johnsy33 wrote:My mechanic didn't recommend doing a pressurized flush on my 98 because of the age & only recommended dropping the pan & letting the fluid drain out for 30 minutes. There was a "sticking" feeling shifting from 2nd-3rd that started developing before the transmission service & now it has almost completely gone away. Thinking about doing it 1 more time soon just to make sure it's all new fluid & maybe that will completely get rid of that slight pause before shift.
A pneumatically pressurized fluid exchange is never recommended. BG relies on the internal pump, Sun on a well regulated pump internal to the exchange unit.
Drain and refill is just adding new fluid to 10 qts. of contaminated worn out fluid. After about 6 consecutive drain and refills, you will get close to one mechanical exchange.
Be sure to drop pan , inspect, replace internal filter and O ring, replace pan gasket and use new one time use bolts.
