http://www.bgfindashop.com/ will let you begin your search. Do call any shop first as the data base is not at all current, but the local distributor will know who has what.QE86 wrote:So does anybody know where I can get a quality flush and how much will they usually cost??
I am in So Cal so will Jerry Tucker in SD able to help with those??
Thanks!!
Thanks for all the input guys, so how much am I looking at doing a flush? And how do I know if the shop is doing a flush instead of just a fluid change? Do they use a machine that is very easy to recongize?? Sorry for all the newbie questions.texasoil wrote:Based on my careful pbservation of 3 different transmission flushes, it takes 14-18 qts of fluid to get the 'coming out' to look as clear and bright as the fresh going in. So--if you first flush with fresh regular, then fill the machine with 14 qts fo M1and then run it dry--you should be +/- 100% M1 fluid.
I suggest a standard flush, runit a week, drop the pan and change the filter while up on the rack at the transmission flush place, and then run 12Qts of Mobil 1 into it.
Yes, watch them. The Sun machine uses clear hoses so you can see the different colors of new ATF vs. used ATF.QE86 wrote: Do they use a machine that is very easy to recongize??
