Transmission Flush How many miles in between?
bigdog76
Car: 1996 Infinity Q45
I had my transmission rebuilt 1 1/2 years agoRight now I have about 20,000 miles on the rebuilt transmission when should I do the transmission flush?
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
7500 Miles for me, Twice a year. One drain and refill. The second with a filter change, and refill. That is the standard here for me living in Las Vegas.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
If by flush you mean a mechanical fluid exchange, then it depends on auxiliary cooler or not, mountains and high speeds or not, urban or highway, synthtetic or not, etc.
Best to exhcange the fluid before you notice any degradation.
A flush technically is a chemical additive to keep contaminants in solution so they will be expelled when teh fluid is completely exchanged. A good recent thread in IOM that discusses and quotes older posts on this subject.
Ever try reading Q45tech's posts? He is the only one who has documented his maintenance routine and quantified his transmission's performance over 173K.
bullittandy
Car: 2003 Infiniti Q45 70K miles
1999 Infiniti Q45 Touring 180K miles
1997 Infiniti Q45 270K miles (sold)
1997 Infiniti Q45 186K miles (junk-sold)
I think it wouldn't be a bad idea to drain the pan every other oil change which for me would be about 10K miles. I haven't made this a rigid habit yet but when I use ramps to change the oil then its an easy move to drain the transmission pan and refill with 4 quarts.
Now this assumes that you do your own work, if I had to pay somebody I would change the fluid at about 30K or so.
Q45tech
Toyota/Lexus use a premium synthetic ATF in V8 [not in old I6/V6 models] and require an annual pan drain [roughly the same 3+ quarts in a Q sump. If this annual 3+ quarts is replaced [30% new additives] the need for a full chemical flush is pushed out above 100K.
Going to Mobil 1 Syn ATF and doing the same ANNUAL PAN DRAIN PROCEEDURE might work after an intial clean up.
ALL DEPENDS ON THE ATF COLOR RATE OF CHANGE FROM HEAT.
qship96
Car: 1996 Infiniti Q45
Qtech you are going to give Brian neurosis with that annual single pan drain regime!
qship96
I wonder if Brian is still with us after reading qtechs post about a single annual pan drain/refill, or if he is lying on the floor in front of his computer having a coronary attack?
NightRiderQ45
Car: 1998 Infiniti Q45
qship96 wrote:I wonder if Brian is still with us after reading qtechs post about a single annual pan drain/refill, or if he is lying on the floor in front of his computer having a coronary attack?
LMAO!!!! You see he didn't reply lol!
qship96
Brian and I have a long standing difference of opinion regarding the effectiveness of multiple pan drains VS machine fluid exchanges here on Nico- probobly dating back 5 years or so....mean time my original transmission still operates like new at 213,000 miles.Other than this friendly difference of opinion, Brian and I are on the same wavelength as far as aggressive proactive maintenance being the best way to prolong the life of the Q while maximising driving enjoyment.A newbie following his advice may spend some coin, but would not be steered wrong.
