Some shops won't do a pan drop filter replacement. Avoid them.chomer wrote:Lastly, the (1) BG shop I found said that with the BG additive, they don't need to go in and replace the screen and gasket. Since I got new ones from Joe @ Infiniti, shouldn't I just put the new ones on, seal it up, and then do the flush? Isn't that a quicker way to ensure that the fluid is good and clean?
That just sounds like an excuse. There WILL be some material stuck in the old filter - and no transmission additive is going to get rid of it. IMO, without replacing the filter, it's a half-assed job.chomer wrote:Lastly, the (1) BG shop I found said that with the BG additive, they don't need to go in and replace the screen and gasket.
A flush is the chemical cleaner added prior to the mechanical exchange.Paul Wall wrote:I am weighing the possibility of having the transmission flushed or doing it my self.
Brian, your above comment PROVES you dont understand SQUAT about what you are preaching regarding multiple drain/fills VS using a machine to exchange atf.maxnix wrote:
Or you could just do six drains and and refills and hope gravity moves the ATF with as much pressure as the pump (it doesn't).
Evidently you don't understand the concept of gravity only vs. gravity and pressure together.qship96 wrote:
FYI, the internal transmission pump uses the atf in the drain pan{AKA the SUMP} as its supply......every drop of atf that gets pumped COMES FROM THE DRAINPAN........so if you unbolt the drain plug and drain the pan, you are REMOVING THE EXACT SAME FLUID and any contaminents it holds- your comment makes ZERO sense,as usual on this topic!
Weren't you the one that said fuel injector cleaner was bad?Victor wrote:I agree a pan drop and cleaning, new filter or old filter cleaned, and new pan gasket are necessary, at least the first time you do a fluid exchange. I reiterate, not a single car manufacturer recommends a power flush, in fact a flush on an old transmission will do more harm then good. A fluid exchange, maybe a couple in a row if the original fluid is really dirty, is sufficient and best for your car.
So did you use their fluid? I don't know about using their fluid because they claim that it's universal. I think that is total BS but I could be mistaking. How is it that they make a transmission fluid that is good for ALL CARS? Has anyone else here had experience the BG fluid. BTW, the term "synthetic" transmission fluid is over used since ALL transmission fluid has synthetic base molecules.oldmako wrote:This trans flush - no flush but drain issue needs it's own website! hahaha
Just as an aside, when I had my BG-job done the guy said that my 14 quarts of M1 wasn't necessary because they used a synthetic fluid during the replacement. I have no idea....but I thought that I'd post this info for the masses considering surgery.
Seems a bit of a stretch since they only charged me a buck and a quarter or so for the whole job and I paid that much for M1. I dunno.
Great info. It wasn't until I got on this site and hearing everyone praise the M1 fluid, I went and jumped on the bandwagon and purhcased M1 and LG Red too. I didn't purchase the transmission cooler and don't plan to. I was upset at myself after researching to find out that ALL transmission fluid has synthetic base molecules to help with the heat. Plus given the fact that my transmission got to 175k off of "dino" fluid, did I really need to buy M1??? You are correct, I think that I might just do the drain & refill from this point foward too. IDK, that's what I say now, but knowing me, I'll probably still do the exchange WITHOUT M1 this time around. Dex-VI will be just fine.oldmako wrote:I used my own fluid. I didn't find out until after that the replacement fluid used by the shop was syn. As for that, I am no chemical engineer (although I did experiment some in high school) and I don't know shinola about ATF other than it's basically hydraulic fluid. I do know that M1 is very expensive, but much cheaper than a new box.
It was by reading all the info here that I got the jones for the expensive stuff. Is it worth it? I have no idea. The car had 120K at the time and I had no idea if it had been ever done. The old fluid was clean and pink an the car shifted fine 99 percent of the time. It seemed a bit funky once or twice but that's when it was extremely cold out. Now days I follow Obi-Wan Q-nobi's advice and don't allow the engine over 2000 rpm until the coolant temp is in it's normal range. I let it idle a few minutes in the driveway then move out in no-tilt grandpa mode. Once it's warmed up and happy I smack it around like a cheap whore. The car has shifted normally since then. I am guardedly optimistic that with the wuss motor it will last a ga-jillion miles.
I also added the lubriguard red and a trans cooler, bypassing the pre-heater in the radiator. It's just juju....spend a little now and keep fingers crossed. Not much chance of me dropping a trans in this mother, I'll push it off a cliff first. From this point forward I'll do the 5-6 quart drain and refill once a year or so. Car has 145K on it now and I'll be satisfied if I can get it to 220-240K. After that, I'll toss it and look for a gently abused 3rd gen Q-fo-fi or a 1967, split window, 12 volt microbus.
